ls engine
Old Nov 3, 2013 | 11:41 PM
Swt SS's Avatar
Default ls engine
I have a lm7 5.3L bored to Ls1 spec's...can I still use 5.3L internal parts in the now ls1 5.7L?
Old Nov 5, 2013 | 01:51 AM
bww3588's Avatar
After everything is rebalanced. Yes
Old Nov 5, 2013 | 08:24 AM
N20zuki's Avatar
Pistons are no longer the same.
Old Nov 6, 2013 | 11:46 AM
Swt SS's Avatar
so I can all 5.3 internal parts except the pistons which have to be 5.7L ?
Old Nov 8, 2013 | 12:51 AM
2000PewterT/A's Avatar
The pistons have to match the bore, you will be able to use the rods and crank from the 5.3 but the pistons are larger for a 5.7.
Old Nov 11, 2013 | 07:21 AM
trjk07's Avatar
You guys probably will fry me for not looking his answer up but I'm not savvy to this site. I have a 04 5.3 with .588 cam around 114 lobe sep. with I believe 228 duration. I want to put these 806 heads that have been ported and 2.02 intake valves on the 5.3. Anyway to trick some compression back with a gasket instead of milling heads. I guess the heads are 66cc?
By Brett Foote | 2026-06-04 05:00:17
