nitrous
Old Dec 26, 2013 | 08:26 PM
package252's Avatar
Default nitrous
Got question. i just install nitrous on my car which is 99 pontiac trans am bone stock.i first tried it with 100 shot and felt pretty good. so i decided to step u to 150. So i sprayed it today with 150. Car went from 1 to 2 gear find but when it was going from 2 to 3rd it went up on rev limiter and wouldn't shift
What would cause that.
Old Dec 27, 2013 | 12:09 AM
JDEP162's Avatar
I don't know all the specifics, but leave it in OD and it won't do that.
Old Dec 27, 2013 | 12:18 AM
HCI2000SS's Avatar
Are you running the stock torque converter?
Old Dec 27, 2013 | 08:15 AM
package252's Avatar
Yes sir i am running a stock convertor
Old Dec 27, 2013 | 09:56 PM
FIVEPOINT7's Avatar
This. My car used to do that N/A with just longtubes, if I tried to manually shift it 1-2-3, the 2-3 shift would bounce on the limiter a few times before it shifted. Left in OD, wouldn't do it. Get a nice stall and a retune and you should be good to go. Best bet is to call one of the reputable stall companies (Yank, Vigilante, Circle D) and tell them what you have done to the car (N2O), they'll suggest a stall, install it and tell your tuner the same thing, stall and N2O, he should get you hooked up.
Old Dec 27, 2013 | 10:06 PM
98CayenneT/A's Avatar
Try a fluid and filter change, mine did that from 1-2, old fluid smelt burnt, new fluid in and no more hitting rev limiter
