another gear question thread
Old Mar 26, 2014 | 08:31 AM
DANOZ28's Avatar
if you dont setup (shim) the gears just right they whine so let your buddy tackle it if hes experienced. i havent done this but have researched for awhile check into adding a solid pinion spacer & replace C clips to help 10 bolt last a little longer. i did add a bearing kit when i had to replace the leaking pinion seal. goodluck!
Old Mar 26, 2014 | 08:44 AM
mcmuscle3's Avatar
thank you!, im doing research on 8.8 swap also. There are so many trash mustangs around I can get the rear for super cheap. I know I may still be stock, However I would like to have some sticky tires and not worry about my rear staying back at the staging lanes while im 1/4 mile down the track. lol
