Battery Problem?
if you have a volt meter, check voltage across the battery terminals with everything off... preferably after the car has sat overnight. if it's 70°F or warmer outside, you should measure at least 12.50 volts. if it's below 12.40 volts you have a weak/dying/dead battery.
