Knock sensor Replacment
Old May 20, 2004 | 10:12 AM
Vertigo's Avatar
Default Knock sensor Replacment
What is involved in replacing the 2 knock sensors. IE do i need to get an intake gasket? I heard that coolent leaks into the oil so you need to do an oil change afterwards...IS THIS TRUE? thanks for the help!!
Old May 20, 2004 | 12:19 PM
thunderstruck's Avatar
you 'shouldnt' need intake gaskets. they are reusable, i have had my intake on and off a couple times and they were fine. and no coolant touches the intake, just be careful of the oil pressure sensor! very easy to break.
Old May 20, 2004 | 12:24 PM
Vertigo's Avatar
Dealership wants $340 to do this job???? Would that be worth it or not? I have all the tools i need and know my under the hood. Just haven't done this b4. THX!
Old May 20, 2004 | 12:26 PM
slt200mph's Avatar
If you take off the intake you must lift it straight up...do not lift the front and not the back or YOU WILL break the oil pressure sending unit..it will cost you $30+ for another one..be advised it is very EZ 2 do...
Old May 20, 2004 | 12:31 PM
horist's Avatar
definetly not worth 340 bux ... it's an easy job... intake manifold comes off , unscrew knock sensors, install new ones, torque to appropriate torque ... reinstall intake manifold and done... maybe a 2 hour job start to finish?
Old May 20, 2004 | 01:51 PM
MOBE's Avatar
Here is a link to jmX's www.ls1howto.com, for the LS1 to LS6 valley cover conversion. The steps you are going to have to take to swap the knock sesors are illustrated in this write up.
Old May 21, 2004 | 09:53 AM
ArticZ's Avatar
definetly do it your self.. I just did one last weekend it was an easy job.. and took about an hour to do
