Sensor Id
Old Mar 10, 2015 | 06:38 PM
Michael_e's Avatar
Default Sensor Id
First , I did try several searches, looked and a lot of newbe threads and went thru page after page and never found a thread or link that shows and identifies the various sensors on the top of a 2002 5.3 truck engine with a 4l60 trans? I'm somewhat sure some of these will be eliminated when the harness get redone for install in a older 50's vehicle?
Any help will be appreciated.
Mike
Old Mar 10, 2015 | 10:08 PM
conan's Avatar
Got any pics of your engine with the sensors in question ?
Old Mar 11, 2015 | 11:40 AM
Michael_e's Avatar
Ok, I got a few pics now.
The first pic is from the front of the engine. What is the tall cylinder sensor?
Now the second pic is the rear of the engine from the drivers side view. On the very top of the intake right behind one of the mounting studs is a square like sensor with a 3 or 4 wire plug. What is it for?
Then, on the drivers side of the intake is a sensor or connector that looks to have two blue connectors. One of those connectors looks to route underneath the intake. Could it be for one of the knock sensors?
Mike
Old Mar 11, 2015 | 02:16 PM
conan's Avatar
In pic #1 that is the EVAP solenoid to vent the gas tank.
In pic #2 the harness that goes under the intake is the knock sensor harness the other sensor that is in the intake is the MAP sensor. Then if you look where the brake booster hose makes the 90* bend, that is the cam sensor and the oil pressure sending unit. The cam sensor is the flat one and the oil pressure is the tall post.
Old Mar 11, 2015 | 07:31 PM
Michael_e's Avatar
Thanks Conan! That helps a lot. May have a couple more pics/questions soon.
Old Mar 11, 2015 | 08:29 PM
conan's Avatar
Post em up we'll get you sorted out.
