Which Cam???????
Keep in mind that many decent-sized cams(the ones you can "hear") will have some surging at low RPMs. I think you have that covered with the 4.10s but still you may find yourself downshifting a bit more into 5th or even 4th if the highway isn't moving too quickly. Cost of doing business and if you have the man transmission you should relish the extra chances to grab a gear anyway.
Mine is 222/228 @ 112+3 and about .560" lift. Decent low end and explosive compared to stock LS2 cam at WOT above 3K. Surges a bit below 1500RPM at light/part throttle but a) I'm teaching myself to tune at the same time so some or all of this is likely my fault and b) there's no fun down at 1500RPM anyway!I think your car came with the LS6 intake but confirm please?
BTW the thinking behind the lopsided duration(more exhaust) is that I can't find long tube headers for LS in a CJ..yet. You've got some nice headers but also slightly less displacement and a little less flow on your(241/853/etc.) heads so I am thinking something more even..maybe a 224/224 with same lift.
This may be obvious to you but worth saying I think..you may have the LS6 intake but still would not have the LS6 valve springs stock..the LS1 valve springs are not good for anything over the stock cam, period.
Good luck with your project.
