newbie mod help
The torque converter transfers power from the engine and multiplies torque.
Your idle may be affected by a higher stall, it depends on what you select.
You want to pay attention to the flash stall not foot brake stall.
The converter will rip the car into rpm quicker and keep the engine in the power band longer. Acceleration will dramatically increase.
The SOP (seat of pants) feel will be extremely noticeable if you change to a higher stall converter and your et can drop half a second or more depending on your selection. And better gripping tires are a wise investment to take full advantage of it.
I would check with the sponsors on the board and pick their brain about which maybe best for your application and budget. The 3600 seems to be common ground for driveability and performance.
