What intake...
Old Sep 18, 2015 | 05:02 PM
btmauldin3's Avatar
Default What intake...
I bought a 99' z28 a4 car and after I purchased the car I noticed it was leaking oil profusely! After doing research on this site I had discovered what I believe my problem was. My oil pressure sending unit was broken into two pieces. Now that being said to replace the part I had to completely remove my intake. My car has a smog delete and egr delete and everyone I have come into contact with says go ahead and find an intake to replace the stock with its a quick easy mod to do especially since mine is already off now. My problem is that I don't really have enough evidence or really a good general idea of where to start. Any help is greatly appreciated and this car is going to be a daily driver at some point it's a project now. I'd really love to find out a good road to start down with this car.
Old Sep 18, 2015 | 05:25 PM
actrite80's Avatar
LS6 cheap hp you can find them on here used
Old Sep 19, 2015 | 01:12 AM
GiggleJuiced_SS's Avatar
Depends on what you want out the car. Ls6 is the best bang for the buck. You can find them around 300 350 used. Get a ported throttle body and that's a very nice upgrade. If you want more, then look in to the fast 92mm or 102mm. The 102mm will require a cpl more things to bolt on.
Old Sep 19, 2015 | 08:00 AM
MonmouthCtyLS7's Avatar
Those things snap so easily, guess its either the LS6 or pony up for the Fast. I recommend the 92mm, direct swap.
Old Sep 19, 2015 | 09:16 AM
HCI2000SS's Avatar
What plans do you have for it?
