Question about hurst skip shift?
Old Jun 8, 2004 | 11:49 PM
2_wacko's Avatar
Default Question about hurst skip shift?
I recently bought the hurst skipt shift and was wondering if the skip shift light is still suposed to come on or not. Mine still come's on is this right?
Old Jun 9, 2004 | 12:10 AM
99'Formula's Avatar
mine doesnt but I have LS-1 Edit but I think if your just buy a skip shift emliminator it still stays on...I think
Old Jun 9, 2004 | 05:40 AM
2_wacko's Avatar
ttt--------
Old Jun 9, 2004 | 06:16 AM
TA TED's Avatar
STF Veteran
Skip shift eliminators will not interrupt the Shift Light Circuit. Either use LS1 edit, or disconnect the light ground discrete at the PCM. Cut the wire and cap the ends. The PCM will store a fault for the lamp control circuit being defective, however it will not trigger a SES light.
Old Jun 9, 2004 | 06:58 AM
DJ_951's Avatar
Yes the skip shift light will come on still. Just smile knowing you don't have to shift to 4th gear.
Old Jun 9, 2004 | 07:12 AM
demonspeed's Avatar
It's not mine! woo hoo!
FYI - the skip shift has nothing to do with a Hurst shifter.
Old Jun 9, 2004 | 07:19 AM
2_wacko's Avatar
I liked the skip shift as soon as put the thing on I just did not know if the light was suposed to come on or not.. Thank's for the info.
Old Jun 9, 2004 | 12:20 PM
Strahley's Avatar
Hurst makes a !CAGS? Didn't know that
Or are you saying you bought a Hurst Shifter? If you bought just a shifter, then no that will not eliminate the skip shift. That's something different
But yes, when you disable CAGS, the "shift" light will still come on. It won't go away until after you have engaged in another gear (normally 2nd)
Old Jun 9, 2004 | 01:54 PM
2_wacko's Avatar
Yes Hurst make's a skip shift some of the sponser's sell it.
Old Jun 9, 2004 | 05:11 PM
demonspeed's Avatar
The way you made it sound was it had something to do with the Hurst shifter itself. I think that's why some of us were confused
