Help bleeding trans!!
Old Sep 30, 2015 | 06:44 PM
z28_YOU_HO's Avatar
Default Help bleeding trans!!
I've been trying to bleed my t-56 with no luck.
I've already drained from the master to the quick connect going into the slave cylinder and now am attempting to bleed from the bleeder valve on the trans.
I am getting NO pressure build up at all and there are no bubbles coming from the resivour. What's going on???
Old Sep 30, 2015 | 09:10 PM
stock400whp's Avatar
buy a mityvac and google how to use it on a fbody.
Ive had the same issues the first time i did mine. 4hrs wasted. then i finally googled it and with the mity vac its an easy 15 min job.
well worth the $35 i spent.
Old Sep 30, 2015 | 11:14 PM
z28_YOU_HO's Avatar
That's what I actually did. 5 pumps in the resivour and pedal was solid as a rock.
