Old May 26, 2016, 04:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Problems by Symptom
Print Wikipost
Ls1 engine problems
Old Oct 5, 2015 | 08:43 AM
GMW96's Avatar
Default Ls1 engine problems
Hello everyone. I got a motor from a 2004 GTO with 89k miles. I had a local machine shop rebuild the motor from top to bottom with new piston rings and all new seals.
I have the motor in my 1996 BMW and have put 7500 miles on it after the rebuild. When I compression tested it my numbers ranged from 148-160ish. I will find my compression test sheet.
I feel like these numbers are very poor. I compression tested my other BMW with 120k miles and original motor and I have from 155-160 across the board.
Also when I pulled the motor I drained the oil and smelled like gas. I think the piston rings are having some issues. Half the spark plugs had oil on them and the other half were dry. The motor also has oil consumption.
Can I get some opinions on what you guys think? The machine shop said the numbers are normal and the motor doesn't need to be fixed.
Old Oct 5, 2015 | 01:21 PM
GMW96's Avatar
Does anyone have an opinion on this?
Old Oct 8, 2015 | 04:04 PM
z28_YOU_HO's Avatar
I would post this in the "Internal Engine" section
