Pre Purchase Help
- wire harness replacement
- ecu replacement
- ecu programming
- engine sitting too high for driveline
Any advice is appreciated that can help me decide if I should pull the trigger. Tried contacting local ls "experts" but guess they are too busy to respond.
Thanks a bunch.
Engine sitting too high isn't really a common problem. The LS engines mount almost exactly like a small block so its a bit hard to screw that up. If the subframe has the stock frame stands, this won't be an issue.
I would worry about how the trans was mounted, what driveshaft was used, what oil pan was used, how well the exhaust was done, and how the radiator/fans is setup.
To be honest, if everything is there, I would worry more about the shape of the actual car. When I built my Nova, I put more money into restoring it than I did the LS swap.
- front suspension is heidts
- rear suspension is tci 4 link
- rear is ford 9" with 3.7:1
- exhaust is redirected to sides in front of rear wheel well due to tci suspension and ground clearance
- what I see in regards to cooling is a tight squeeze between radiator and engine with this sequence: radiator, fan(s), intake filter, engine. There doesn't appear to be enough room between fan and engine to put a 90 degree elbow and redirect intake filter to side.
- from what I can tell the I don't see any issues with the car other than needing interior
The guy wants $11K for car so I figure if getting it on the road and fixing any issues doesn't go nuts I'll be ok. It's just that there are alot of non stock components here and making sure they all work together might require an advanced engineering degree for me.
In the end, it is a bit of a crap shoot. That said, here are some suggestions we followed (and learned)
#1. Quality and detail of work. It doesn't have to be perfect or concourse level - but how did they route wires, what hoses did they use for brakes, fuel, etc. How cognizant were they of clearances, fit, etc
#2. Quality of parts. And they don't have to be most expensive. But if you've got expensive, good heads and totally crap headers. Why?
#3. What works and what doesn't will tell you what care and thought process went into the build.
We went recently to look at 70 GTO resto mod. Paint was great. LS1 ran fine. But they didn't put in temp or oil pressure gauges. In my mind - what kind of car person does all that work and leaves out most basic gauge ? And the custom made center console was held down by Velcro. Really?!
Walked away. And it worked out. Week later found our 02 TA
Good luck. It's all a gut thing in end if your at least somewhat versed in cars. Trust your gut.
