P0301 Code
Try carefully pulling one plug wire at a time where the noise is loudest. If the noise stops or is significantly reduced, then it's probably a wrist pin. Running it low on oil can easily smoke a wrist pin. It's not good for lifters either.
Give a good cleaning a chance to clear it up if you don't find anything upon inspection. You can use brake cleaner and engine flush to clean it. Only run the engine at idle, for about 5 minutes. Use the brake cleaner to spray directly down the pushrods.
Then change your oil and pray.
