Car running rough / missing
The issue is once warmed up, if i shut it off and let it sit for a few minutes and then fire it back up, it will miss and run rough intermittently, for the first minute or two. After that it will run awesome until i shut it off again.
This issue started after installing the ls6 intake manifold.
Any ideas???
The new intake is probably causing a/f ratio's to be outside of parameters, or they are just bad.
Wouldn't a vacuum leak occur when the car is running cold as well?
Let's us know what you find
