Lq9
Old Sep 2, 2019 | 10:34 PM
Giovanni Navarrete's Avatar
Default Lq9
I know this ls1 tech but need some help
got a 04 Silverado ss with lq9 motor took ****
got a l76 engine with ls3 heads cam intake and all accessories
1st. does the water pump work with clutch fan or need e-fans or can I use lq9 water pump?
2nd. What exact reluctor convertor do I need
3rd. Will all my plugs and sensor will be same or need to change some with new pig tails?
I will I’ll also be getting retuned
Old Sep 3, 2019 | 08:07 AM
JoeNova's Avatar
Restricted User
1. You'll have to swap over full truck accessories if it doesn't have them already. If it does, you can just swap water pumps.
2. 58x to 24x. Lingenfelter. They aren't made the other way around, there shouldn't be any mixups.
3. Cam sensor will be in the front of the engine so you'll need an extension harness. Knock sensors are on the sides of the block.
Old Sep 3, 2019 | 08:40 AM
The lq9 accessories would work right? I have everything off the lq9 n some stuff off the l76 but I know the intake will not work so I’ll have to buy a relocation bracket to fit the ls3 car intake
