LS6 Intake Question
I just received a used LS6 intake and when it arrived the piece on the rear that the MAP sensor goes into was loose. I wiggled it around a little and it fell out. One of the tabs that holds it in was broken and it looked like someone had tried to superglue it in and obviously it didn't work. I used liquid ABS plastic weld to repair it but I do not know what GM used to seal it so there is no vacuum leak? I tried to find if there was a part number but had no luck, anyone here ever done this repair?
that piece is not available separately .....it is held in by the tangs of the piece
when I got my LS6 mani that piece was damaged....I cut my old LS1 mani apart to get that piece out
it is almost impossible to reach those tangs holding it in to compress them to get it out
