P0481 code on 2000 trans am
ive bench tested the Rad fans,
both fans come on low when driving as they are supposed to.
After driving for a bit eventually 481 comes up. I've tried swapping relays from position to position and test lighted and multi metered at that C100 connection
I thought it was the blue wire under relay 2 possibly with a **** connection, so I ran a new wire and code still comes up.
I'm not very good with electrical, but on connection J(dark green) I think on c100 connector going to the relay side I get 12v. I got nothing on the blue one. Which is the one I cut and ran a new wire as I had read that was supposed to show 12v.
I'm pulling whats left of my hair out. I testsd the relays and they seem to be doing what they are supposed to so my only thought is something is shorting out. I don't believe it's pcm related but i had a hard time understanding the testing side of the c100 to the pcm from what I read.
I am about to consider just running a manual fan switch and see about putting in the diodes or whatever to make the code not show.
Any insight would be greatly appreciated.
Will update once I recieved and installed.
