Head Swap.
Old Feb 28, 2023 | 03:43 PM
KobeGigi's Avatar
Default Head Swap.
Hey Fam. I am doing a head swap on my 01 TA. Do I need to drain the coolant from the heads by removing the drain plugs on both sides of the block? Is this even necessary? Or is it just a simple head swap and dont need to mess with the drain plugs or any other type of stuff where coolant goes and comes? Thanks in advance.
Old Mar 1, 2023 | 09:50 AM
MplSS's Avatar
When I did mine, I just drained the radiator. I think either way, you'll end up with a small ocean of coolant on the floor!
Old Mar 1, 2023 | 03:59 PM
LS1 TJ's Avatar
Make sure you blow all the coolant out of the head bolt holes.
