Gears
Old Oct 10, 2023 | 11:31 AM
Jona2023's Avatar
Default Gears
Hi hope all is well. I have a 2000 trans am ws6 with stock heads, magic stick 4 ,and 4000 stall, 4l65e transmission. My question is wich gear should I run 390,or 373 not much experience with 4l65e trans I grew up with 350 turbo, and 400 trans. Thanks alot fellas
Old Oct 10, 2023 | 12:57 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
As you have a WS6, assuming it was originally a 4L60E (none of them came with a 4L65E, so the trans must've been swapped at some point) car then it would have come with 3.23s stock. With a 4000 stall speed already in place there is almost no performance advantage to a 3.73 swap, so you'd have to go numerically higher (like 4.10+) to see any real gains. The only advantage to a 3.73 would be to slightly "tighten" the feel of the converter at part throttle (if that's your reason for swapping). If you want significant performance gains, then 3.73 will be a waste of effort/money given your current setup.
Old Oct 10, 2023 | 02:00 PM
Jona2023's Avatar
Default Ok
So ill try the 390 then one guy was saying 390 was too much but it's never gonna be on highway only drag strip and back country roads
Old Oct 10, 2023 | 02:41 PM
RPM WS6's Avatar
I would probably just go to a 4.10 if you're not worried about highway driving. Anything less might be disappointing (in terms of additional gains) given the stall speed you already have.
Old Oct 17, 2023 | 11:40 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
It might be a 4L60E, maybe he thinks it's a 4L65E.
4000 stall,what brand ?
Old Oct 17, 2023 | 01:11 PM
Jona2023's Avatar
Default Transmission
I stated 4l65e that's what it is it was bought and tci stall
Old Oct 17, 2023 | 01:24 PM
Jona2023's Avatar
Default Trans
yes the trans was swapped and 4000 stall was added
