wont start
Old Dec 27, 2023 | 11:29 PM
Darth Maro's Avatar
Default wont start
i have a 1998 Chevy Camaro it has a ls1 with t56 transmission. i brought it out to go do some last minute shopping with my friend for Christmas. the thing ran like a top no issues, no ticking lots of power, and shifted smoothly. i was then on my way home after wards on the highway and was going much faster than i need but wasn't anything new for that car. i remember going about 90-100mph in about 5th gear somewhere around 4000-4500rpm and it just turned off the car just lost all power. i panicked when i saw the rpm/oil pressure drop so i turned the key back to try and turn it off, then i coasted to the side of the highway and stopped. i got out checked fluids, spark, fuel, and it was normal and the car just refused to restart. i had to have my buddy flat tow me home ( thankfully i wasn't far). My buddy thought that i had hit a bump and it kicked the starter out and kicked the starter out based on what i was telling him (PS the car is lowered on stiff suspension). so replaced went and replaced the starter and it still wouldn't start I'm stuck at this point all that's happening is the car will turn over freely and back fire out the exhaust and wont start. doesn't make the normal crank sound either. i cant figure out how to attach a video. its hard to explain but when i crank it it doesnt sound normal it almost just sounds like when it turns over with no spark plugs in it. any thing helps thank you (PS car is bone stock with a ls6 intake and long tubes).
File Type: mov
Old Dec 28, 2023 | 06:46 PM
jetech's Avatar
Veteran: Air Force
Sounds like it has little to no compression to me. Did you check for compression?
Old Dec 29, 2023 | 04:02 PM
ghardester's Avatar
Seems like the bottom part of your engine is turning over, but the top part, the valve train is not. You probably lost the timing chain, either broken or off the gears. Pull a valve cover off and see if there is movement when you try to start it.
Old Dec 30, 2023 | 10:57 PM
Darth Maro's Avatar
no i haven't had any time since it happen but i certainly will
Darth Maro's Avatar
ill pull a cover and see what happens i didn't even think of that thank you
