Piston choice depends on your power goals and budget. My build is a perfect example of that. I went with Summit ProLS pistons with a 2CC dome, because I'm not planning on more than 1000 HP. Don't believe everything you read about compression and turbocharging. I'm going to be right around 10.5:1 when my engine is complete, which is a good number for an E85 fueled combo. If you want to run on pump gas, you'd want less compression, but you say you're already on E85. So bumping up compression now won't hurt anything. If you're on a budget, go ahead and stay with what you have for pistons, but if the shortblock is stock, you'll want to tear it down and gap the piston rings. Also, if you have Gen 3 rods, you'll want to swap them for Gen 4 rods at minimum, or go with aftermarket. Lots of people boost stock bottom ends to crazy power levels, but a lot of people also blow them up. Good rods and pistons can help a boosted engine live a longer life. Also, my cam recommendation wouldn't be great in a boosted engine. Depending on what LSA your present cam is, I'd just run that. It would be more than enough for boost.
