2 questions!
2. After you fut your engine off does it vibrate a little bit? I mean right after you turn the key off i get a little bit of vibration from the engine. Is this normal too?
Thanks
Brendon
Hard to tell from your description of the vibration if you are experiencing "run-on" or not. Try using a higher octane gas for a tank or two and see if it eliminates or reduces the issue.
"Deiseling", i thought the same thing.and yes my car hisses just after shutoff too.
about the hissing, mine does that to and it got more noticable after the lid install, its just the vaccum your engine sucks in, its releasing it
I dont remember how to get rid of it though.
I did a quick search on Google and found this:
http://www.misterfixit.com/diesling.htm
http://autorepair.about.com/library/faqs/bl494b.htm
http://doityourself.com/auto/tunedieseling.htm
http://www.sportcompactracing.com/au...rm/250,1,xhtml
http://mgaguru.com/mgtech/engine/ro101.htm
Most of those are for older engines, the last one is pretty detailed.
From what I read in those is that you should try some GM Top-End Cleaner (or the appropirate cleaner -- to remove carbon deposits which contribute to the issue), use good gas of the proper octane (91+ in our case) and gas made for the current season. If the problem persists, there may be an issue with the throttle body not closing all the way, the injectors may be leaking fuel into the engine, the engine may be running really rich (the left over fuel is still igniting), the timing may be too far advanced, or others.
i didnt mention this before cus i believe there to a differant cause with his car,
Texasheat, i would take it in for a check just to be sure if the warranty is still good.
I would say that i am a spirited driver. I will go WOT at least once or twice a day, other than that i keep it below 3K rpm. I use chevron premium 93 octane. I was running shell v-power, but i was getting bad gas mileage. Like I said before the car was doing this when i first got it. So it has been a while. I have 46,000 miles now so i think it may be time for some top end cleaner anyway.
