RPO Option Code Database
AC3
ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AK5
RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9
SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A90
LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B35
COVERING, REAR, FLOOR MATS, CARPETED INSERT
B84
ORNAMENTATION, EXTR MLDG, BODY SIDE
RPO Code auo Not Found In Database
AU3
LOCK CONTROL, SIDE DR, ELEC
CC1
ROOF HATCH, REMOVABLE PANELS, GLASS
C49
DEFOGGER, RR WINDOW, ELECTRIC
C60
HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C90
LAMP, INTR, FRT AND RR DRS, COURTESY
DG7
MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
DL5
DECAL, ROADSIDE SERVICE INFORMATION
FE2
SUSPENSION SYSTEM, RIDE HANDLING
FE9
CERTIFICATION, EMISSION, FEDERAL
GU5
AXLE REAR, 3.23 RATIO
G80
AXLE POSITRACTION, LIMITED SLIP
V73
ANTENNA, FIXED
Z28
MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY
STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1SC
OPTION PACKAGE 03
12B
TRIM COMBINATION, CLOTH, GRAPHITE (B) (92)
12I
INTERIOR TRIM, GRAPHITE (92)
17P
WHEEL COLOR, SILVER (91)
37Q
MOLDING COLOR, DK BRIGHT TEAL MET
37U
EXTERIOR COLOR, PRIMARY (DARK BRIGHT TEAL METALLIC) (92)
RPO Code 6hd Not Found In Database
K34
CRUISE CONTROL, AUT0MATIC, ELECTRONIC
RPO Code ipb Not Found In Database
J65
BRAKE SYSTEM, PWR, FRT & RR DISC
K34
KG9
GENERATOR, 140 AMP
LT1
ENGINE, GAS, 8 CYL, 5.7L, TPI, HO
RPO Code mxo Not Found In Database
M30
TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
NA5
EMISSION SYSTEM, FEDERAL, TIER O
NP5
STEERING WHEEL, LEATHER WRAPPED
N96
WHEEL, 16 X 8, CAST ALUMINUM
QLC
TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
r7a
CONTROL SALES ITEM 26 SPECIAL OPTION PROCESSING
RPO Code r7r Not Found In Database
ste
PLANT CODE - ST. THERESE, PQ, GM OF CANADA
T96
FOG LAMPS - FRONT
UB3
CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
U82
SPEAKER SYSTEM, 3, DUAL DR MTD, RR PKG SHELF
RPO Code nm3 Not Found In Database
cae
GM ST Therese LaSalle Quebec for Upfitter Conversion (Thanks to 2001NBMZ28 @ LS1Tech)
7bs
Spring suspension, front RH (Thanks to 2001NBMZ28 @ LS1Tech)
6bs
Spring suspension, front LH (Thanks to 2001NBMZ28 @ LS1Tech)
qfk
Tire, All 275/40R17-93 BW HW4 (Thanks to 2001NBMZ28 @ LS1Tech)
nf7
Emissions System, Federal (Thanks to 2001NBMZ28 @ LS1Tech)
aka third brake light. The Best V8 Stories One Small Block at Time
CHMSL = Center High-Mounted Stop Light
