Total Electrical Shutdown. Help.
Old Mar 7, 2005 | 06:05 PM
jammon46's Avatar
Unhappy Total Electrical Shutdown. Help.
This afternoon I was washing my car and then pulled it into the garage. 2 hours later, I went to start it up and nothing happened when I turned the key. I popped the hood, took a gander at the battery, jiggled the terminal connectors, turned the key again and the lights and clock came on for a second. So I turned the key all the way and it gave me that click like when your battery is dead. It is a brand new optima red top though so I doubt that, also this has happened before but never for this long. Please help me.
Old Mar 7, 2005 | 06:15 PM
92CamaroReallySlow's Avatar
You might have left something on that drained the battery, did you try and recharge or jump start the battery to see if it will start up. I would try that before being concerned it is a more serious problem.
Old Mar 7, 2005 | 09:29 PM
Camaroz's Avatar
Check your connections make sure there tight it sounds like a loose connection if when you screwed with them **** came on etc
Old Mar 7, 2005 | 09:33 PM
jammon46's Avatar
tried to jump it... nothing. Took the battery out, put it back in, worked perfect. WTF
Old Mar 7, 2005 | 11:07 PM
Camaroz's Avatar
lol... loose connection just double check them and tighten if needed...
Old Mar 8, 2005 | 12:52 AM
'Trust''s Avatar
Happened to me once, then i realized it was in Drive
