Squeek!!!!!!
Hot squeak emerge
So now I have this hot squeak. As you drive the car around and it warms up more it becomes very noticeable. When you slow down for a stoplight or stop sign I get a lovely squeak when I apply the brakes (as the weight shifts forward), then when I left of the brakes and the car comes to a neutral balance (alla stopped at a light/stop sign) and then I get another squeak when I start moving again (the weight gets transferred to the rear). You can make the suspension squeak like all holy hell if you pump the brakes ie get on the brakes, off the brakes, on the brakes, off the breaks in essence making the car "buck". (noise as far as I can tell comes from both the back and the front, louder in the back)When the car is cold you can go to all the fenders and push/pull do whatever and they don’t make a noise. After the car starts making the squeak you can get out and pull up/push down on any fender and you will get a squeak. Also once it starts making the noise you can go over speed bumps and the front will make a slight squeak, and the back if I recall correctly won’t.
Any Idea’s?
HELP ME!!!!!!!!!!!!!!!!!
Tightened: about everything in the rear suspension.
Lubed: Sway bar bushings, sway bar end links, lower control arm bushings, panhard bar bushings.
All that got rid of the goes over bumps/its cold sharp squeak. Now I have one that only shows it head after the car has been driven for a while like over 15 miles (I think it really depends on how much stopping and going and turning and how bumpy the roads are). And it happens every time the weight of the car is transferred. But it is especially noticeable when the car is stopping/taking off.
Really, you can probably get by with just one friend, but if you take several you can all go out to celebrate if you succeed in locating the squeak!
Some shops also have some kind of magnetic mircophone that you stick under the car and listen to while you drive - they just keep moving it around until the find the problem. Time consuming, but it usually works.
But ya know.. I romp on it.. and I don't seem to give a **** about any of the other things anymore.. wonder why that is? :-D
