Test drive, threw a code?
10/07/05:
Took the car to an autoparts store, and had the car scanned.. Results were:
P0131
P0137
P0151
P0157
P0530
The first four are related to the O2 sensors, and I wanted to know if that's likely to have been thrown due to running out of gas? They also just replaced the AC compressor so I believe that's why the last one was thrown too?
Any comments or opinions would be welcome. Thanks you guys.
I went down to a local carlot, as they had a 98 z28 there. (Darkblue, nbm maybe?) The car has about 104k on it, but they're asking about $7k for the car.
Test drove the car, ran out of gas while doing so =P.
The guy came out, put some gas in the car, and it drove fine. However.. after it ran out of gas the SES light came on, and stayed on.. I drove around for about 10 minutes longer and it never went away.
Does anyone have any ideas as to what this could be? I was told possible O2 sensor freaking out because it ran out of gas? Should I just forget about this car?
PS.
This was my first f-body driving experience, and even with the nonsense, I loved it. I *will* have one of these cars, perhaps not this one, but one none the less =P
) so it could be something simple as that, if you're interested, go back and have the dealer tech scan the code (with you watching of course), then you can see what the problem is (remember the number and you can look at what the code is here)
Certain parameters have to be present for the test to be run again. I believe the car has to cool down again before it can be started because the intake air temp and coolant temp have to be within about 15 degrees of each other. So leaving it over night and starting it in the morning would be good, or at least for a few hours.
Even if the CEL goes out, have a mechanic scan it using a Tech 2 as the code it threw will be stored in the History. I think it requires at least 30 or more drive cycles to clear the code from History, unless the battery is disconnected for a while or someone purposely clears the codes with a scan tool.
After a few clean starts it should go away....or you can pull the battery and engine fuse to clear the code and see if it comes back on, but I know that I would rather know what the code is before I'd buy it.
Peace,
Craig.
10/07/05:
P0131
P0137
P0151
P0157
P0530
