I need Power!!!!
What I want to do: Fast LSX intake, Bigger throttle body, headers,y-pipe, high flow cats.
The Situation: Been thinking about supercharging but deciding to hold off due to money and seeing my friend blow his motor (haha).
So what can I do for lots and lots and lots of more power? I'd like to get parts that will not need to be removed or replaced when the day comes for supercharging. I know you all have some sick rides....So give me some secrets and suggestions. Warm days are nearing.
It's true a 90/90 setup will produce more power, but it'll also cost a 4 figure number, this money can be better spent else where.
First off are you auto or manual?
If auto get a new stall, maybe something like a Yank PY3400.
Final drive ratio will also make the car much more livley. 4.10 is popular for manual cars and 3.73 for auto's. This won't produce any power but it will feel like it does
The only snag is, you will one day break your 10 bolt axle and then upgrade to a 12 bolt or a 9" which will sadly make the replacement gears redundant. This is either something you accept or you save for a new axle before doing the gears.For more power, get some LT headers (lots of good makes, Pacesetters are worth a look if on a budget), plus a new Y pipe. TSP offer a catted Y along with ORY (off road Y) and do deal kits with Pacesetter headers.
Then get yourself a nice cam kit, about $1500 all in so this is where that money you saved from the LSx manifold can be spent. Don't go too wild with the cam if it's your daily driver, but a 224/224 is probably a good starting off point. Thunder Racing have some nice cams and complete install kits.
If you plan on track use then some sticky tyres such as DR's will help ET's but your stock 10 bolt won't be too keen on them.
With the mods you have and the ones above with a good tune 380-410rwhp is perfectly doable depending on what cam you go for.
After that you really want to look at suspension mods, then it's onto supercharging
you can buy the cam used on this board, push rods and valvesprings, gaskets from gm and some tools for the job for $500 total.
If you live near Atlanta I can do it in one afternoon and it'll be cheap labor. I've done several cams and I have it down to about 7 hours for the job. -Joshua
