traction control
You shouldn't post pics of your little sister, she isn't here to defend herself.
I have driven in horrid thunderstorms with no problems. If you drive a camaro in the snow, you have problems.
From my experience, it has nearly caused several accidents while saving none. By the time it kicks in, it has already allowed the back of the car to slide to one side or the other enough that does not prevent losing traction... it fights against a smooth recovery by immediately killing the throttle. It would be a better system in my opinion if it would smoothly decrease throttle instead of the sudden let off.
When the car is on snow or ice, it allows the wheels to spin quite a bit before it engages which means you get zero traction from a dead stop. I start out in second or even third gear to reduce the torque through the gearbox and have far less problems.
I would personally not order a car with TCS if I had the choice though I would not refuse to buy one if it came with it. I'd just shut it off every time I get in like I do now.
I drive a peweter WS-6 with black black bird stripes. You wern't down at AZ Power & Sound the other day were you?
