Compression numbers on an engine I'm purchasing...
Old May 30, 2006 | 05:51 PM
jasonst's Avatar
Default Compression numbers on an engine I'm purchasing...
I was told that all compression #'s came in between 190 and 200 on 8 cylinders tested.
Oil pressure was 55 cold and 45 hot.
I did a quick search, but didn't find anything. I will look again, but if a couple of you could post whether these #'s are fair, good, or awesome, I'd greatly appreciate it.
Regards,
~Jason
Old May 30, 2006 | 06:07 PM
'Trust''s Avatar
Those numbers are good, 100 is considered a dead cylinder and anything above 180 is great.
Old May 30, 2006 | 06:08 PM
'Trust''s Avatar
Oh, and GM minimum PSI on oil pressure is like 18 PSI at idle, a good general rule is 10 PSI per 1000 RPM, so your golden
Old May 30, 2006 | 06:18 PM
2K2WS6TA's Avatar
Oil pressure 55 cold 45 hot was that at idle, or driving
Old May 30, 2006 | 06:55 PM
jasonst's Avatar
Oil pressure was at idle.
Thanks for the comments.
~Jason
