Octane Question
"Premium fuel in a car designed for unleaded will give you benefits as its a cleaner fuel, leaves less deposits, better performance/economy (higher octane rating)"
Now I thought that cars the require regular unleaded burn different and technically using premium would actually leave deposits because it's not being "burnt" properly. Am I crazy or is he right
Now octane rating stands for the combustability of the fuel. High octane fuels don't combust as easy and thus allow higher states of tune of boost with less risk of detonation.
You won't automatically pick up HP using higher octane fuel. Some cars do, mostly turbo's but they need the electronics such as anti knock to be able to do this.
The new s197 Mustang is rated to run 87 octane. Running 91 or 93 won't really give you any HP unless you get the PCM tuned for it. But it won't do any harm either.
Now this is where it's a little odd, as I think the 87 octane fuel has slightly different content and generally is cheap by comparison. Not sure of the exact content but I think premium has a form of cleaner in it which is good for the engine/injectors.
Don't run 87 in a car tuned for higher octane though, this will pull timing as a best case and reduce power but it may cause detonation and just run like crap and cause damage.
