CAM question
Old Dec 7, 2006 | 08:45 PM
TA1972's Avatar
Default CAM question
Hi, I just wanted to know what the hp difference is from these two cams? One cam is 03 zo6 cam and the other is a ls1 custom grind cam similar to hotcam. Here's the specs:Grind Number# HR-279-CSB
Valve Setting:
IN./Hyd.
EX./Hyd.
RPM Operating Range:
1800 to 6600
Duration:
Advertised IN./.275 EX./.287
@.050" IN./218 EX./228
Valve Lift:
1.7 Rocker: IN./.558 EX./.558
Sprins: LS6 or equivalent
Lobe Sep. Angle:
IN./116
EX./116
Old Dec 11, 2006 | 01:21 PM
lsx24's Avatar
Do a search for Hotcam.
Old Dec 11, 2006 | 01:53 PM
JayplaySS's Avatar
Moderator
Dont waste your time with anything less than 224/585/112-113 IMO
Old Dec 11, 2006 | 03:25 PM
SHINER's Avatar
you cant necessarily base hp ratings off cam grinds. The Hotcam I would think is a lil more aggressive than the LS6 cam. The Hotcam has a Tighter LSA meaning your gonna lope more and you wil reach your power band faster.
Ultimate hp ratings is decided upon many things including ultimate compression ratio(head gaskets have alot to do with this aswell), and what type of cylinder heads are being used.
Also, remember NO two cars will ever dyno the exact same. Every motor is different.
If you are looking for a mild/streetable cam I suggest either the TR224 or 228.
Let us know what your goals are, so we can better help you.
Old Dec 11, 2006 | 03:40 PM
98Z28MASS's Avatar
+1...Your going to need to upgrade your valvetrain with either of those cams, so why not run a bigger cam? TR224 is a prove performer, so maybe try that. Also, do you have all the bolt ons such as lid, ls6 intake, headers and catback/cutout?
Old Dec 14, 2006 | 11:14 AM
aaronbetzner's Avatar
Those are pretty mild. I don't think I would go through the hassle of the install for something like the hotcam. Just my opinion but I think you will agree eventually.
Old Dec 14, 2006 | 11:41 AM
SHINER's Avatar
I think if you want something mild go with the TR224. This cam is probably one of the most popular grinds for the LSX motor. Excellent driveability.
You can find the grind at Thunder Racing or Texas Speed and Performance.
Old Dec 14, 2006 | 01:55 PM
lsx24's Avatar
Go with a smaller cam if you want off-idle tq, like the venerable Comp Cams 216/220 114 lsa.
