difference in LS1 years
Old Dec 25, 2006 | 04:56 PM
nissanic89's Avatar
Default difference in LS1 years
ok gotta question did a lil research and i cant seem to find anyhting. I am wondering what the diff is between 97-02 LS1s as for my project im finding 98-99 LS1s pretty cheap and i am wondering if the power difference is in the computer, or the heads comrpression or whatever else. Can u make the power of an 98 or so LS1 with a computer upgrade, chances are that ill be running megasquirt so would that over come the power difference, "ie tuning". Just wnating to know the difference betweent the years thanks alot guys.
-chris
Old Dec 25, 2006 | 05:13 PM
bmxer8699's Avatar
if memory serves me correct the 97's werent ls1s..
Old Dec 25, 2006 | 05:20 PM
TransAminal's Avatar
In the Corvette they were...
Old Dec 25, 2006 | 05:27 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Can't find anything? Did you check the stickies at the top of this forum?
This is what you want:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Old Dec 25, 2006 | 05:48 PM
nissanic89's Avatar
https://ls1tech.com/forums/showthread.php?t=213148
oh thank you so iguess there isnt really a huge difference between all of them hmm have to keep that in mind, except for cams, thanks big help
Old Dec 25, 2006 | 05:51 PM
RPM WS6's Avatar
No problem.
Keep in mind if you're buying a complete motor the '01+ motors will have the LS6 intake.
Old Dec 25, 2006 | 06:02 PM
JAY ROD's Avatar
00-01 ls1's had some piston ring issues in corvettes.
Old Dec 26, 2006 | 12:55 AM
nissanic89's Avatar
is that just in corvettes?
Old Dec 26, 2006 | 01:28 AM
Rob98LS1's Avatar
I won't be suprised if someone chimes in and says that all 98 Camaros/trans ams had a bad oil pump. But that's just not a proven fact as there are so many 98's that haven't a problem with that. Just throwing that in there for you.
the earlier ls1's had larger cam and egr, NO ls6 intake.
the later ls1's had smaller cam, NO egr, and a ls6 intake.
that's all i got.
Old Dec 26, 2006 | 08:42 AM
CJDZ24_Z28's Avatar
yup most people will say stay away from the 98's. Harder to tune,weak oil pump etc.. i peronally seen a 98 with 187k on it and it ran great! Here is another even higher mileage
http://www.autotrader.com/fyc/vdp.js...500&cardist=70
Old Dec 26, 2006 | 09:17 AM
LS1Formulation's Avatar
I'd buy that car today if I had the money. High mileage cars don't scare me a bit.
Old Dec 26, 2006 | 10:05 AM
RPM WS6's Avatar
I hope you guys are aware that the '98-'00 LS1 all had the same exact oil pump. The revised one didn't come out till '01.
A '99 or '00 car has just as much risk of random pump failure as a '98 car.
Actually, the only guys I've known to have pump failure have been '99 owners.
Old Dec 26, 2006 | 10:39 AM
YellowMonster87's Avatar
01/02's also may have ls6 block as well.. thers a post on here somewhre of how to identify this if or when you buy the motor....
Old Dec 27, 2006 | 01:12 AM
Rob98LS1's Avatar
tho the ls6 BLOCK won't give an increase in power.
Old Dec 27, 2006 | 01:22 AM
fuseone's Avatar
no wont but still makes its differnent from the other yrs
Old Dec 27, 2006 | 01:24 AM
jimoc's Avatar
Mid-year 00 cars got the new pump - 241 heads are a good indicator that it has it.
Old Dec 27, 2006 | 02:00 AM
98goldz28's Avatar
I have a 98 and have no problems with the oil pump yet. I have 135k miles on it she does not leak any oil or have the piston slap some of the others ls1 cars have.
Old Dec 27, 2006 | 02:09 AM
sdavis2702's Avatar
http://www.smokemup.com/tech/ls1.php
there's a little write up just for a little more technical info
Old Dec 27, 2006 | 02:19 AM
BLKWS.6's Avatar
98-00 had worse lifters, worse rod bolts, worse oil pumps, and no chance of an LS6 block, as well as an LS1 instead of an LS6 intake. The 98 can only be honed .05 and the 99+ can go .010 (I am very sleepy, there may be another 0 in front of those #'s).
The 01+ got a smaller cam, bigger injectors, LS6 intake, LS6 clutch and hydrolics.
99+ IIRC got a Torsen differential and hte 98's had the Auburn
98 had the only usable gas tank cap tether and the only guages that really registered anything (temp, ect, I think that was ended with the 99' production and now we get "dummy guages" on the temp).
98-00 had different exhaust manifolds
01-02 got pup-cats and deleted the EGR
the 4L60E had weak sun gears in 00 from what I heard
Some people say the 01+trannies have carbon-fiber syncros, others deny this
The 02 cars got a napier faced oil ring and are less likely to use oil overall.
I am sure I could go on, but I think I got the major ones.
Old Dec 27, 2006 | 02:21 AM
nissanic89's Avatar
thanks guy, so just curious can you swap oil pump?
