Is It True
Old Apr 12, 2007 | 03:35 PM
RoCkEt's Avatar
Question Is It True
Is it true that in order to tell if your car is an original T/A the second letter in your VIN would be a W?
Old Apr 12, 2007 | 03:41 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Are you asking in regards to '93+ Trans Ams?
If so, the 2nd digit in the VIN will ALWAYS be a "G". Whether it's a Trans Am or not. The 2nd digit has nothing to do with model or trim level.
Old Apr 12, 2007 | 03:46 PM
RoCkEt's Avatar
I wasn't aware the year played a hand in this. I was asking a friend how you would be able to tell the difference between a T/A and a Formula and he said that in order to tell if it is an original T/A the second letter in the VIN would be a w. So the second letter has absolutely nothing to do with it???
Old Apr 12, 2007 | 04:26 PM
021less's Avatar
nope, the second letter in the vin is usually in any car the first letter of the make, in this case it should be G, Fords are F
Old Apr 12, 2007 | 04:53 PM
NDFORSPD's Avatar
yeah the second digit always denotes the manufacturer, the first is the coutry it was man/assembled in. could be correct on the "w" being a TA(from early 90s), dependin on the year the letter may change, but its placement in the vin stays the same
Old Apr 12, 2007 | 05:03 PM
infinitebird's Avatar
No, as said above. It is relatively easy to tell the difference between a T/A and a formula anyway. The T/A has the high rear spoiler, side ground effects, the lettering on the doors and back center panel says "Trans Am" etc.
Of course, you can change all those things on the formula if you want to, but not many people do that since the T/A is not really of a greater value than a formula, unless it's a ws6 T/A. That does increase the price some usually, and to tell that you can look at the rpo sticker.
Old Apr 12, 2007 | 05:40 PM
RPM WS6's Avatar
I beleive it was in 1981 or 1982 when the structure of the VIN number changed. For all modern GM cars, that second digit will always be a "G". You might be correct on the "W" thing if you go back to the '60s/'70s or something.
Old Apr 12, 2007 | 06:56 PM
bww3588's Avatar
the 93 T/A's had the forumla/6'er rear spoiler. just check your RPO's. on the 93 model they are inside the glove box.
 Michael S. Palmer
Old Apr 13, 2007 | 01:29 PM
greysteel_M6's Avatar
93 T/A GT's got the raised spoiler.
Old Apr 13, 2007 | 01:53 PM
RPM WS6's Avatar
RPO "T43" got you the raised deck spoiler.
Old Apr 13, 2007 | 05:41 PM
RoCkEt's Avatar
Ok all of that was really helpful. I knew about the T/A having the lettering on the back panel but as you said people change that! Cool well now I can tell the person who told me that the second letter in the vin was W that he is stupid hahaha.
