a/c problems.
Old May 2, 2007 | 10:48 PM
NxLS1496's Avatar
Default a/c problems.
my ac blows cold but only problem is it will not blow on my face or anywhere else. only on my feet. it also blows on the windshield just a little bit. no matter what setting i put it on it still does the same thing. what is up with this?
Old May 4, 2007 | 05:05 PM
trickymick's Avatar
my car did the same thing. under the hood on the passenger side there is a check valve for the vaccum system that controls the a/c controls. its at the back of the engine compartment under some wires. mine had holes in it and broke into pieces when i touched it i guess from getting old and brittle. there are 3 vaccum lines that go to it. i went to the dealership the piece is under $10 just swapped it out and it works again.
hope this helps
Old May 4, 2007 | 05:07 PM
HIPER-Z's Avatar
Had this problem, and it wasnt the lines, they were good, it was the compressor thing in the dash, and had a bad ground is what they told me.
Old May 4, 2007 | 05:50 PM
2001NBMZ28's Avatar
Only blowing on the windshield/feet is the default setting - check for a vacuum leak behind the intake.
Old May 6, 2007 | 06:55 PM
NxLS1496's Avatar
cool, ill check that out guys. thanks.
