Intake question.
There's a artical under the free mods section about removing excess plastic under the air filter for MUCH better breathing.
If you look at a SLP FLowpak, you get a good lid, some shitty rubber bellow which doesn't give you 1hp on the dyno, and a metal air duct that is mounted between your A/C condensor and the rad... it draws in fresh, cool air from under the front of the car, rather than sucking in warm air from the engine bay.
The duct probly doesn't add any hp, but on warmer days, it should help keep your car fairly consitant on the track, specially when doing back to back runs.
jeez didnt you read the article? haha what would be the easiest device to cut it with? all i think i have is a hack saw....but that'd be hard to cut into the corners with.
you can use a dremel (prob Easiest) if you dont have one I used my drill and a cutting tip worked just fine
I now have a dremel and would use it first
same with CAGS (skip shift)
Did you notice much 5_02? And was that your first mod?
[QUOTE]Yall must be confused too. lol[QUOTE]
whats wrong here???
1.no car info thought you had lt1{sig pic}
2.make fun of what another member tells you{drill holes that sounds ghetto}"kinda racial"
3.look at things before posting unless gm screwed up on your car that airbox is open in the front..
4.if you know the answer and have searced and viewed it why ask....
I was only tryin to help but you had to be a little know it all smartass....
whats wrong here???
1. Posted that i had a 00 Z28
2. Not making fun and it's not really racial just kinda half-assish
3. I already posted that i found that it's open earlier in the forum
Example from first page...
4. I posted the question and found the answer, the topic completely changed and you quoted something earlier in the thread, that was already covered.
Thank you very much.....smartass.
Whats wrong here? You keep quoting stuff i say and answering them way after it's already been covered. You should read the whole thing before you start accusing me of being a smartass.
Confusing...
