Traction HELP!!!
Old May 18, 2007 | 11:42 PM
SSmoked!'s Avatar
Default Traction HELP!!!
Just like the title says!! I dont know **** about traction and what to do/buy to get some!! so can some of you guys help me out. I just got a tune and with all the mods (in sig) I have my first gear hops so i need to get the power to the ground!! any help or links to other posts would be great!! thanks felas!
Old May 19, 2007 | 12:02 AM
wldesyWS6's Avatar
SUSPENSION: subframe connectors, Panhard Bar, Lower Control Arms, Torque Arm...
or maybe just better tires, Nitto 555R are ok, but not the greatest
Old May 19, 2007 | 01:51 AM
Blk97WS6's Avatar
Well first off, with those tires and an M6, if you get any traction, that 10-bolt is most likely doomed. But if your not worried about that, then what is mentioned above will help out a great deal. Might also want to add some LCA re-location brackets to that list as well.
Old May 19, 2007 | 01:52 AM
Blk97WS6's Avatar
Also, make sure your clutch is up to the job as well.
