Fibbado, I agree completely, a tune is definitely worthwhile and necessary after modifications, even if they are just minor like headers and exhaust. Glad we can see eye to eye.
On a Duramax diesel, a tune is the first mod I'd do. But for the rest of civilization running gasoline powered cars there aren't many that will benefit at all from it.
You will not gain any power with a tune. There is nothing good to be had on a stock car with a tune (Besides skip shift etc). Save the money for the bolt ons, but make sure you can still afford the tune after the bolt ons.
Not worth it with minimal mods. I didn't get tuned when I did my headers and exhaust, because I knew I was going further. It wasn't worth it to spend 500 when I was going to have to pay again after the cam and heads. I lived without the extra 10hp or whatever for a bit. Find out where you will be stopping at mod-wise for a while and get it tuned after that. That's where it will make a difference and be worth it.
Yah. You're spot on, the average enthusiast knows how to tune these cars better than the genius who built it. Right. GM build it, and tuned it, to make the highest amount possible whilst still retaining a margin of error for the unexpected. Like a bad tank of gas. Like a bad fuel filter. Like your wife putting 85 in. If you want to throw all of this safety out the window, and trust the gas companies who are making love to your prison hole, go ahead. But I'll be 5hp down from you, and with a running engine the day we both get a bad tank.
Contrary to what you might think, most experienced tuners (of which I am one) have never blown up an engine. If you are going to tune your car yourself, you definitely need to do your research first, however it's not THAT hard to learn to do, and there are many people on this forum who can help you out.
Originally Posted by FieroZ34
So let's see this proof. I want a before and after dyno on a STOCK car with just a tune.
I'm not just talking about power increases. Yeah there's not a lot of power to be gained stock, but there's other things that are helpful. Lowering your fan temps to let the engine run cooler, tuning out cags, tuning out air/egr, torque management, vats, traction control, ses codes, changing shift points and shift firmness (on autos), changing speed and rev limiters, calibrating the maf for better fuel economy, raising/lowering idle, advancing timing, plus many others.
I CLEARLY said STOCK CARS. That doesn't mean the guy who took a hacksaw to his exhaust system. That means someone like me, who hasn't so much as touched the engine on their Camaro, right down tot he paper air filter. I then clearly stated that tuning a car is a good idea once you modify it. But if you are going to tune out your O2's, you may as well install a carb, as you've just taken away one of the biggest functions EFI brings to us.
No you haven't. I'm only referring to the rear O2s obviously. Again you don't really seem that knowledgeable on how these engines operate it seems. There are two sets of O2s (on 96+ cars), the front and rear. The front ones are the important ones. They make adjustments to the fuel mixture based on the amount of oxygen detected in the exhaust gases. Virtually no one gets rid of these (except people who want to run open loop tunes like some turbo guys). The rear O2s on the other hand do nothing but let the computer know if the cats are working as expected. That is their sole function. So like when you remove the cats, the computer will set a code that the rear O2s have detected an error, this is what you tune out. The rear O2s are most definitely not "one of the biggest functions of EFI". That's just funny.
How so? Because I understand GM fuel injection because I have spent over 8 years studying and modifying it, only to figure out that on a stock car, it really isn't possible to outdo what the factory did and retain the margin of error?
As I mentioned in my previous post, not everyone here cares about maintaining the same margin of error GM was. Everyone has different goals and ways they want to use their car. What is fine for you might not be for someone else.
Find me one gas station that gives out perfect gasoline, EVERY GALLON. Then you can safely run more timing than stock. About enough timing to give you 4-5hp. I've done this, on many cars, only to be quite unimpressed with the results.
I'm sorry but this is a dumb arguement. Yeah no gas is perfect. But it's also quite possible to be very safe about it. Example: on my last car I advanced the timing a little, and did multiple datalogs with different gas which verifyed that I still had no knock. Yeah it might be the case that I could get some bad gas at some point, but as you point out, the knock sensor will correct this if/when it happens.
And you can. The only consequence is that for those first 8 engine cycles, you will ping. But after that, it will be safe. You may only make 200hp, but it will be safe to do so.
Well, at least you are right here. Yeah the computer will switch to the low octane tables and will pull a bunch of timing. Exactly why you don't want to do this.
I haven't needed to work on any of my LS1s. The day I do, it goes to the dealership under warranty
I think you just summed up the difference in your philosophy with most of the other people on this site. It all makes sense now.
I removed AIR and EGR on a friend's LS1 a few eeks ago. I;ve since put both systems right back on the car. It REEKS of exhaust for the first 10 minutes of run time. It is to the point that it gives you a headache. GM made the cold-start maps under the assumption that these systems would be on and operational. Removing the AIR system does the same thing as removing the cats for the first 10 minutes of runtime.
Interesting, well maybe they have a better flowing exhaust than most people. I haven't noticed the same on cars I have seen with this done or on my car.
I'll give you that one too, however there's a reason GM put a 6-speed in the cars. My shifts are however I want them to be.
Totally agree there.
When it comes to the PCM and EFI, GM did get everything right. That is one of the few parts on any GM vehicle that I can honestly say is perfect.
Again, I must disagree, due to numerous things I already mentioned.
Even in the old days of OBD1, they were still fantastic.
Uh oh, now you've just hit the jackpot on the absurdo meter.
As someone who owns and tunes an OBD1 car, I can tell you that there are a plethora of things GM didn't get right on these. Like for example you can get 10+ rwhp stock just by correcting the a/f ratio. The stock setting tuned the WOT a/f for about 11.2, which is way richer than it needs to be. Then there is the fact that you can't run more than a 2800-3000 stall on these cars or the computer has a fit and switches to the trans limp mode. There is a fix for this with tuning. Or the fact that you can't spin the motor past 7200rpm under ANY circumstances, even if you have the setup to do so. Or the fact that it's very hard to run multi-bar MAP setups on these computers for turbo people. Or the fact that the stock knock settings don't work well at all if you have any exhaust mods, I could go on and on...
Again, nothing personal here dude, I just happen to disagree with just about everything you have to say.
