Problems with shifting
Old Jun 18, 2007 | 01:11 PM
downtown_ss's Avatar
Default Problems with shifting
I've just recently bought a 2000 SS Camaro in good shape and runs great. The car has a 6 speed and the clutch feels good in the car and has no problems shifting just in normal driving conditions. But when i rap it out and shift at high rpm's like if i was racing, either i cant shift into the next gear or i can but the clutch does not come back up when i let off it stays on the floor...anyone else experience this or know how to fix the problem.
Old Jun 18, 2007 | 01:26 PM
Zealot's Avatar
You need the drill mod, do a search and you can find all the info you need and more
Old Jun 18, 2007 | 01:52 PM
Ricks99ls1's Avatar
Scammer Alert!
yes, drill mod, i still have to do it myself, but i was at the drag strip, getting excellent launces, and first-second shifts, then third would not engage, hopefully after the drill mod, ill be ok, let us know
Old Jun 18, 2007 | 02:00 PM
Daredevil_TA's Avatar
Yep what these guys said, basically whats happening is your fluid is getting too hot and is expanding causing it not to make it thru the restricted line. What I would also suggest is to get an 01-02 Master and Slave cylinder since this is a much better design.
Old Jun 18, 2007 | 02:35 PM
Thanks guys...Im gonna do the mod this week and will let you know how it goes.
Old Jun 18, 2007 | 03:04 PM
-LS1-'s Avatar
Mine does the same thing (i also haven't done the drill mod yet), and keeping the clutch fluid in the reservior fresh and clean has helped mine immensely.
