skip shift
Old Jan 17, 2008 | 11:47 PM
Crimsonnaire's Avatar
When the skip shift "locks" out the gears, does it lock the gears from spinning, or does it lock the gear stick from being able to be set into the positions for those gears?
Old Jan 17, 2008 | 11:48 PM
TR GTO's Avatar
It just locks them from going into those gears.
Old Jan 18, 2008 | 12:07 AM
That's a relief! Thank you very much.
I admit it would be somewhat confining to have to shift into 4th gear all the time.
Old Jan 18, 2008 | 10:53 AM
TR GTO's Avatar
It only does it if you're less than half throttle in 1st gear I believe and below a certain RPM. There are bypass modules that are easy to install to disable skip shift. I'm sorry I don't know more about it, mine is an A4.
Old Jan 18, 2008 | 11:47 AM
tspence45's Avatar
Here, the WS6store has it for $18.99 with free shipping right now. http://www.ws6project.com/user_stor/...3a794c49b1022a. It also says exactly what CAGS is and what it does in there too.
Old Jan 18, 2008 | 05:35 PM
Midnight02's Avatar
It typically engages at part throttle in first gear between 15 -20 mph. When engaged, you are simply blocked from shifting into second (as it pushes you into 4th gear). Pretty cool that a $20 clip in connector could eliminate a function that saved us over $500 on the gas guzzler tax!!
Old Jan 18, 2008 | 05:51 PM
overkill-lt1's Avatar
unless something goes wrong with it like mine.it activates eveytime i start the car.i resoldered my resistor and it went back to not activating at all.
the resistor is in line to the cags unit same idea as the skip shift elimininator.except my resistor cost 25 cents.
Old Jan 19, 2008 | 12:44 PM
DBEST369's Avatar
whoever posted this.....all i have to say is WOW
Old Sep 4, 2009 | 06:24 PM
johnlv6's Avatar
I just picked up my '99 SS last night and this is already driving me nuts (city/slow driving). Is this the right part?
http://www.jegs.com/i/SLP/847/21008/...oductId=760249
Old Sep 14, 2009 | 12:47 AM
manwithhate's Avatar
i hate the skip shift but you get a programmer and its gone
Old Sep 14, 2009 | 01:31 AM
mikedamageinc's Avatar
Thats it. I've got one I'll send you one for 15 bucks. PM me if you want it.
Old Sep 14, 2009 | 07:49 AM
  #32
the_merv's Avatar
Veteran: Air Force
Originally Posted by Crimsonnaire
What happens when you try to shift into 2nd? Is the gear stick prevented from rotating down, or does it set in, but the gears don't mesh?
It's a Solenoid on the side of the Tranny that when it engages it locks into a groove on this part here..
This piece sits in the Shift Rail and is the piece that meshes with the Shift Pattern Plate below it, these two pieces guide the Forks into their proper Gates. The groove on it makes it go directly into 4th Gear from first when the CAGS Solenoid kicks in. The groove is located on the right side of it(in refrence to the pic), and is right infront of that Plug that you see in the pic. That is a Plug that I made and installed where the CAGS Solenoid would have gone.
The way CAGS works is it engages above a certian RPM in first, and makes you go to 4th for "cruising".
Old Sep 14, 2009 | 08:01 AM
  #33
johnlv6's Avatar
I appreciate it, but I picked an SLP unit up on Summit (got to install it this weekend). What a difference that makes.
Old Sep 15, 2009 | 03:21 PM
  #34
Thats cool.
So you're in VA, have a 99 SS and a 97 TLC like me, what are the odds!?
Where in VA are you?
Old Sep 15, 2009 | 03:24 PM
  #35
johnlv6's Avatar
Thats cool.
I'm in Fredericksburg (down the road from Iron Pig). How about you?
Old Sep 16, 2009 | 02:36 AM
  #36
I'm in the burg too, not too far from Iron Pig. Got a site with the cruiser on it like cardomain or something?
Old Sep 16, 2009 | 08:09 AM
  #37
johnlv6's Avatar
I've just got a few pictures on photobucket. I was going to lift it, but I decided against it (didn't want to spend the money and make it ride like $hit). Granted OME is supposed to ride great, but I wasn't all that impressed with how my brothers '00 100 serious rides with the 2" OME kit.
It has 285's, IPOR skid plate, and ARB w/IPA's. It's a good rig, but I don't drive it much anymore (for obvious reasons, lol.).
http://s4.photobucket.com/albums/y11...urrent=LC1.jpg
http://i4.photobucket.com/albums/y11...Cruiser/LC.jpg
Old Sep 17, 2009 | 10:16 AM
  #38
Looks good, I really like that color.
They dont ride too bad dependingon the setup. I have the Slee heavy springs and not quite enough gear to weigh it down so it's pretty tight but I dont mind it. On my other cruiser I had the J springs and it rode nice but was at stock weight, no bumpers, etc.
Are you on the ih8mud forum...(Now that the thread is way off topic anyway!)
Old Sep 17, 2009 | 11:11 AM
  #39
look up getting a programmer some will take that off
