Coolant Flush
Old Nov 21, 2007 | 10:09 AM
CK9887's Avatar
Default Coolant Flush
Well I changed my thermostat last night so I lost most of my coolant. When I went to the autoparts store for new coolant they told me not to mix dex-cool if there had already been something else mixed in the system. I wasnt sure if the car had ever had the coolant changed in it before so I wasnt sure if it was Dex-cool or not already in the system.
So he pointed me to a coolant that he said will mix with anything. So I just filled up my system with that. Its green like typical anytifreeze, not red like dex-cool.
Is this ok? It says its safe for all makes and models but I have heard several people say not to run the green coolant
Any help would be good
Thanks
Old Nov 21, 2007 | 10:12 AM
fastSS_LS1's Avatar
Gm puts in Dex-cool. It has a life span of 5 years, instead of the regular anti-freeze which lasts 3 years. I believe it voids the GM warranty if you put in anything else except dex-cool
Old Nov 21, 2007 | 11:50 AM
JohnnyC's Avatar
Any anti-freeze that is O.K. for use in Aluminum engines will work just fine, just do a good flush first and keep the anti-freeze changed every couple years.
Old Nov 21, 2007 | 07:14 PM
waldershrek's Avatar
You can change it over completely to either green (regular) or just add more dex-cool (red) but don't mix the two or they will make a sludgey mess.
Old Nov 23, 2007 | 02:42 PM
CK9887's Avatar
The coolant I added doesnt say its safe for aluminum but it does say its safe for all makes and models and will mix with any coolant
Old Nov 23, 2007 | 02:57 PM
MemphisZ28's Avatar
im kind of interested in this, bc i added the unversal green top off described above, and had dex cool... did i screw this one up? lol
By Brett Foote | 2026-06-04 05:00:17
