Voltage Problem?
Old Mar 26, 2008 | 10:09 AM
S P E E D's Avatar
Default Voltage Problem?
I recently got my 98 WS6 car up and running with some light damage. I took it out for a haul to see how everything checked out. The car pulls hard and everything is good but I noticed on the scan gauge that the battery voltage started out at 14.4 Volts then while cruising around the voltage dropped to 13.6 Volts. What kind of voltage are you guys seeing? The reason I ask is because the previous owner mentioned something about the car throwing (2) o2 Codes from time to time. He changed the o2's and I only saw the 131 and 151 code once since I last took it out.
Old Mar 26, 2008 | 11:13 AM
2001NBMZ28's Avatar
Mine's the same way, think it's normal.
Old Mar 26, 2008 | 01:13 PM
S P E E D's Avatar
I was beginning to think the o2 codes being thrown might have had something to do with the low voltage. But it hasn't thrown the o2 codes in 2 weeks so I guess it's all good.
Old Mar 26, 2008 | 04:01 PM
98FreakZ's Avatar
anything over 13 volts means that your alternator is charging the battery just fine. only time you should worry is when it starts to dip to the left side of vertical or if it drops consideribly when the lights, blinkers or radio are on.
then i would have it looked at
Old Mar 26, 2008 | 06:32 PM
S P E E D's Avatar
Yeah everything checks out like no dim lights or anything like that. I'll tell you one thing though...that Aero Force Scan Gauge is a really nice piece.
Old Mar 26, 2008 | 09:26 PM
dbrown's Avatar
My car starts off at about 16 then levels out to 14 when it warm...
