Oil drain plug?
Old Sep 13, 2008 | 04:49 PM
Joshu's Avatar
Default Oil drain plug?
Can someone please tell me where this sumbitch is and possibly post a picture?
What size is it?
Neeeeeeeeewbie here
Thanks!
Old Sep 13, 2008 | 05:26 PM
conan's Avatar
get under the driver side of the car you'll see your oil filter hanging down the side of the oil pan the drain plug is right in front of it. 15mm size
Old Sep 13, 2008 | 05:32 PM
Joshu's Avatar
Is the drain plug facing the driver's side tire?
Old Sep 13, 2008 | 05:45 PM
Joshu's Avatar
GREAT
the freaking bolt is stripped.
now what?
Old Sep 13, 2008 | 05:49 PM
primer84z's Avatar
take it to an oil change place.
Old Sep 13, 2008 | 05:56 PM
the_merv's Avatar
Veteran: Air Force
Vice Grips..I assume you mean the Head of it is stripped..
Old Sep 13, 2008 | 06:22 PM
Joshu's Avatar
The grips only seemed to strip it further
Old Sep 13, 2008 | 06:38 PM
the_merv's Avatar
Veteran: Air Force
You get a good bite it shouldn't..
Try a small Pipe Wrench.
Worse case scenerio- grind a flat spot on each side of the rounded head that will fit a regular wrench and use that.
Old Sep 13, 2008 | 06:42 PM
kidcamaro98's Avatar
weld another bolt on top of it and wrench it off.
Old Sep 13, 2008 | 06:49 PM
Joshu's Avatar
I'll have my father give it a try, he's pretty built.
Old Sep 13, 2008 | 08:40 PM
*98TransAm*'s Avatar
i work at an oil change place and i have seen some damn tight drain plugs and ive always been able to get them off, i know its a pain in the *** when the vise grips slip off but just keep at it, take both hands (one on each side) of the vise grips and squeeze as hard as you can. i like to tap the vise grips with a hammer to try to loosen the drain plug(one hand hold the vise grips the other tap with hammer). if it keeps slipping off make sure to change the spot on where your putting the head of the vise grips.
Old Sep 13, 2008 | 11:47 PM
primer84z's Avatar
If you have air tools, get the chisel and put it up against the side of it and hammer it towards the left so it loosens it.
