help
Old Sep 14, 2008 | 03:51 PM
BlkBird2000's Avatar
Default help
What snaps into this spot? I have a plug right next to it with no place to plug it in. I had to of unplugged it from somewhere!
Old Sep 14, 2008 | 04:08 PM
nemss1's Avatar
vaccuum purge valve for the AIR injection system
Old Sep 14, 2008 | 04:32 PM
My engine sounds like it's misfiring and I have NO (0) oil pressure. I have no idea where that valve is or what it looks like. Anyone have an pics of it?
Old Sep 14, 2008 | 04:33 PM
BTW this is a ls6 intake. no air or egr.
Old Sep 14, 2008 | 04:45 PM
nemss1's Avatar
if u dont have AIR/EGR, u dont need that valve/solenoid. it is for the AIR injection system
something else is causing u to misfire and have no oil pressure
Old Sep 14, 2008 | 04:47 PM
nemss1's Avatar
did u remove the AIR system? do u have AIR tubes on your headers? 01-02 cars still had the AIR system regardless of different intake (LS6) but didnt have EGR
Old Sep 14, 2008 | 05:00 PM
TA-Swede's Avatar
Nothing you do with your intake should be able to affect your oil-pressure. (Unless you dropped something into the heads).
The misfiring could be because of a vaccum leak somewhere around the intake.
Old Sep 14, 2008 | 05:02 PM
nemss1's Avatar
speaking of vaccuum leaks, check the vaccuum port on the back of the intake and the hoses coming off of it. the vaccuum purge valve/solenoid u are missing connects at a T fitting on the back of the intake
Old Sep 14, 2008 | 05:07 PM
LS184's Avatar
if its reading no oil pressure, and its running fine then u broke ur oil pressure sending unit while doin the intake
Old Sep 14, 2008 | 05:10 PM
TA-Swede's Avatar
Ah, doh, why didn't I think of that? That's the most common thing to go wrong when doing an intake swap...
Old Sep 14, 2008 | 05:12 PM
LS184's Avatar
ya that damn sensor is a pita
Old Sep 14, 2008 | 05:16 PM
nemss1's Avatar
im swapping intakes soon. anything u would recommend so i dont break mine?
Old Sep 14, 2008 | 05:18 PM
TA-Swede's Avatar
Yep, be very careful.. And lift up the rear of the intake when you're pulling it out.
Old Sep 14, 2008 | 05:19 PM
nemss1's Avatar
thank u
Old Sep 14, 2008 | 05:23 PM
LS184's Avatar
ya it helps to have a few extra hands around, have someone unplug all the **** from the back as u lift the intake all the way up till it hits the cowl and then pull it towards u after u have lifted it up slowely...evn doin it slow and carefully can break the sensor, they sometimes snap as easy as a toothpick....just take ur time
