New Products Showcase Come inside to see the newest hardware!
New from Trick Flow
Old Nov 13, 2012 | 09:54 AM
TrickFlowTech's Avatar
LS1Tech Sponsor
Default New from Trick Flow
Here is the new 255cc LS3 head that a lot of you have been waiting for. Yes we have introduced it before but not like this. In order to give you the best product we can we went back to t...he drawing board and made it better.
-Fully CNC ported with CNC profiled chambers
-Utilizes LS7, 12 degree valve angles with LS3 rocker arms and LS3 intake inlet shape
-Ductile iron seats and powder metal valve guides
-(2) Standard spring options
-Standard and 6 bolt head bolt machining options
-High Strength 2024-T4 aerospace aluminum rocker rail (OE LS3/L92 will not fit the TFS LS3)
-Solid stem 2.165"/1.600" valves with 8mm stems
-Slotted water ports in the deck to fit all LS blocks and head gasket combinations.
I will also be posting updates on this product as time goes on so once again keep your eyes open.
__________________
Old Nov 15, 2012 | 08:54 AM
Brian Tooley Racing's Avatar
Looks good! Can you tell me what the intake valve weight will be? Will it have hollow stem valves like your competitors? Thanks.
Old Nov 15, 2012 | 04:24 PM
Sales@Tick's Avatar
Bad ***!
Old Nov 19, 2012 | 07:50 AM
LS1Tech Sponsor
As of right now, they will have solid stem valves. I will post weights when I get them.
__________________
Old Jan 15, 2013 | 07:43 AM
LS1Tech Sponsor
Check out page 3 on the online catalog for all the information regarding the LS3 heads soon to be released.
http://trickflow.com/media/pdfs/catalog_2013.pdf
__________________
