340 LPH Fuel Pump
Granatelli Motor Sports introduces a New Series of In-Line and In-Tank 340 liter per hour Electric Fuel Pumps. The all new “Granatelli Signature Series” line of pumps are high-output electric fuel pumps that fit the most popular EFI applications. Intended to mimic the original equipment compact, lightweight pump in size and shape, the similarities stop there. The Granatelli Signature Series Pumps can out flow the factory by as much as 100% without increasing current draw or stressing the factory wiring harnesses yet they still fit into many existing hanger assemblies.
Why Granatelli over the competition? The Granatelli Signature Series Fuel Pumps offers a broad flow range as compared to other popular pumps in the same category. As an example, at 45 psi most Granatelli Signature Series pumps flow more than 340 lph. That’s 30% more flow than a standard 255 lph. So whether used as a universal replacement for applications that require more flow in the stock configuration or location or as an all out dedicated pump to feed your latest forced induction beast like turbocharged and supercharged applications, Granatelli may just have the pump for you!
Fits most vehicles where popular aftermarket pumps are applicable.
• Offset Inlet design, In-line with outlet
• Includes universal filter sock*
• Pumps for in-tank and external use applications
• Turbine pump mechanism increases durability and can be used in pulse modulated applications
(returnless).
The Granatelli Series of In-Line and In Tank Pumps Include:
• Pump
• Universal Drop Parts Kit (Filter, Wiring Pigtail, Rubber Hose, (2) Clamps, Rubber Grommet)
*Universal filter sock – may not fit in some applications
