New Products Showcase Come inside to see the newest hardware!
MM341 Solid LS Motor Mounts
Old Jun 23, 2020 | 01:57 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Default MM341 Solid LS Motor Mounts
New Product Alert‼️
FOR IMMEDIATE RELEASE
1993-2002 F-Body Solid Motor Mounts
MM341 - $49.95
Reduce engine movement and improve throttle response on your LS equipped 1993-2002 F-Body with Solid Motor Mounts from BMR Suspension. The factory mounts are designed to absorb noise and vibration for a smooth ride, but do little for performance. Constructed from ¼-inch laser cut steel plate, our F-Body motor mounts offer uncompromised strength and rigidity. The BMR Solid Motor Mounts (MM341) eliminate engine movement by removing the soft factory rubber bushings. The MM341 Solid Motor Mounts will allow for instant acceleration, quicker than a polyurethane bushing or rubber bushing due to zero flex or deflection. BMR has designed the MM341 for street performance, drag racing, and handling applications. Installation time is 2-3 hours. Available in red or black hammertone for long lasting good looks. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit
www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
— at BMR Suspension.
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
