NOSzle issues......
No bog & car runs very powerful w/ regulator & low pressure.
my only thought is if you are not famailar with flowing nos i would set to 6.5lbs leave it a lone and tune with jets once you get a tune you can go
up and down with same pattern ie;24/28 to 26/30 you dont have to stay square all the time our best results where with a 2 jet spread
last advice i can give is if you have tr6 throw them in the garbage
got the kit all on and setup within the last few weeks. want to be ready to run oct 4th. cant let you northern boys beat up on me too bad.
after the 4th, maybe i can find a few days to come up and hang out and we can see about making some stupid power.
or i will pm you
i am going to spray oct 4th. i will call you tomorrow.
how late are you at the shop?
is it an off the shelf plug that i can buy local?
im there late 7.00pm
if you cant get them ill have my guys bring you a set on the fourth
Ken...Please advise what plug to use. Also, what fuel pump are you guys using? I have a stock in tank with a Vortech T-rex in line. My bog is definately enough to make a difference at the track. (I got rained out friday night)BUT I can promise you it falls on its face, completely unloads the tires and then launches again. This is still @ 28/28 jetting @ 5.5 psi on fuel pressure. I dont want to go any lower on pressure but do not have 26 jets and no one local has funnel jets. I have 24's but would rather wait and do it one time.
what is fuel pressure on your system when NOT flowing? When mine is NOT flowing it is over 15psi(pegging the gauge) when it is flowing it is 5.5.
