problem running propane through NXL injectors?
Old Sep 13, 2003 | 02:24 PM
BigPlanTransAm's Avatar
Default problem running propane through NXL injectors?
with all this buzz about propane i was wondering if it would work with NXL's injectors. i would like to go direct port but i also like the octane rating on propane(and the $$$) so do you guys think there would be a problem running propane through there or should it work problem free?
Old Sep 13, 2003 | 02:38 PM
CAT3's Avatar
Restricted User
Default Re: problem running propane through NXL injectors?
Inmy uneducated guess, if the injecotrs can flow Nitrous and gas, then it shoudl be able to allow two gases to flow thru, unless the liquid gasoline does something for atomization, which in theory seems like the liquid would hurt atomization more than help.
I dont know, but that was my orignally my idea also, clean install, nice rails, and guaranteed distribution.
Old Sep 13, 2003 | 02:42 PM
thats what i was thinking but it's never a bad idea to ask first
Old Sep 14, 2003 | 12:54 PM
slow's Avatar
the NXL system uses the same rail for injectors, and for the input to their fuel noid, you would not be able to do propane without adapting the input of the NXL system to an auxilary source.
Ryan
Old Sep 14, 2003 | 03:11 PM
CAT3's Avatar
Restricted User
Slow, reportedly the NXL is able to run off from a dedicated fuel system, so that shouldnt be a problem.
Old Sep 16, 2003 | 09:09 AM
smokinHawk's Avatar
why use direct port with nitrous/propane? it isnt needed.
and start out with baby steps when using propane.
Old Sep 16, 2003 | 10:21 AM
Phate's Avatar
A buddy of mine is using propane as the fuel for his n2o system. It is working out really well for him. He is not spraying through the injectors though, he was using it througha 'wet' shot.
He stole the idea from me, since I am using it as a octane booster/charge cooler on my boosted setup!
Old Sep 16, 2003 | 10:36 AM
slow's Avatar
awesome
I was not aware of that.
Ryan.
Old Sep 16, 2003 | 02:22 PM
smokin, i was wanting to use it for the reason scott said: as an octane booster. but i would rather go direct port for the obvious reason so i was wondering if this may be a cheap alternative to $4-5.00/gal racegas
Old Sep 16, 2003 | 02:48 PM
CAT3's Avatar
Restricted User
The only reason I wanted to use it in a NXL is for the clean *** install. Other than thatm your right there is no benefit to the DP setup, just looks really nice!
I guess a set of rails and new line, then a wet propane kit and I will be set!
Old Sep 16, 2003 | 05:09 PM
Brains's Avatar
If you wanted to run propane into the NXL nozzles with the integrated LS1 kit, you'll need an alternate "fuel log" and solenoid. The LS1 kit replaces your fuel rails, and delivers fuel for the kit from that same rail normally -- but nobody says you HAVE to connect the NXL nozzles' lines to the rail. I'd disconnect that fuel solenoid on the rails though, or it'll be one nice fuel shower under there
