Window switch and shift points
Old Oct 20, 2008 | 11:19 AM
KH504's Avatar
Default Window switch and shift points
I have a 01 TA auto bolt ons yank 3200 373 HSW 125 shot . What should I set my window switch and what should I shift at and how far up should be the rev limiter.
Old Oct 20, 2008 | 10:37 PM
somws6bird's Avatar
Set the window for 3200on, and 5900 off, set limiter, to 6000, possibly 6100
as for shifting it,
its an auto leave it in drive, your better off.
Old Oct 21, 2008 | 09:18 AM
Z-RATED94's Avatar
Different car and set-up (LT1), but my limiter is at 6900. Even though the way the limiters work between a LT and a LS are different, do you really want it that close to the shift points on nitrous? Just curious.
Old Oct 21, 2008 | 09:25 AM
KH504's Avatar
I was thinking rev at 6400 ,shift at 6150 and window switch 3000-6000 what do you think
Old Oct 21, 2008 | 10:20 AM
Z-RATED94's Avatar
Sounds like a good starting point to me.
Old Oct 21, 2008 | 10:31 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
+1....shift point and rev limiter will depend on the power curve
Old Oct 22, 2008 | 10:40 AM
Nick@HSW's Avatar
Just make sure you set your nitrous off point before the rev limiter.
Nick
